During a load rejection governor
During a load rejection governor automatically switch its operation mode to "Isolated Network" with a speed control mode, and start closing the Distributor.
The dynamic response of regulators speed is slower than the rate of increase of speed of generators s (Approximately 8% / s).
2 things happen:
1- Partial shutdown(86PS) by overspeed relay.
2- Total shutdown (86E)by Automatic Voltage Regulator for failure Excitation Second Stage
How to resolve this problem?
RE: During a load rejection governor
Mike L.
The excitation system should absolutely not trip on load rejection. Since these are likely static exciters, there shoud be almost NO change in stator voltage on a full load trip. The settings must be non-optimal, perhaps all-wrong...
rasevskii
governor and AVR are ABB.
During a load rejection, there is a violation of the absorption capacity of reactive power by the Estreito Hydro powerplant and consequent loss of control of the voltage set value.
The loss of both AVR channels causes a fault trip 86E.
