Mirror Failing
Mirror Failing
Mirror Failing
Good day all, see attached screenshot. Why won't the "flange" mirror?
Extrude-Thin 1 is a circle drawn on the front plane, Extrude-Thin 2
circle was offset from the cylinder edge and extruded.
Solidworks 2011.
Thanks in advance.
Mike
RE: Mirror Failing
Try mirroring the body, not the feature.
Jeff Mirisola
Director of Engineering
M9 Defense
My Blog
RE: Mirror Failing
JMirisola, thank you for that. I had tried that earlier with a more complex part, with no luck. What I didn't understand was that it seems the body has to be selected from the graphics area by picking on it, rather than from the feature tree. Sound right to you?
I have got a long ways to go with Sworks.
Mike
RE: Mirror Failing
You should be able to select it from the 'Bodies' folder as well.
Jeff Mirisola
M9 Defense
My Blog
RE: Mirror Failing
Right click on the Feature Manager and select Hide/Show Tree Items.
I'm guessing the Solid Bodies folder is set to Hide ... or you have no bodies in the more complex part.
RE: Mirror Failing
In your first image, you won't see the Bodies Folder unless you switch back to the FM.
RE: Mirror Failing
CorBlimeyLimey, yes, the Bodies folder was hidden in both parts. Now set to Show. As I said, a long ways to go...
Thanks to both of you.
Mike
