Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...These forums are an excellent source and example of the way people can help each other..."
Geography
WCJ (Geotechnical)
27 Jun 12 11:03
In thread323608 tom1953 wrote, in part:
>>jclarkw, I've got a copy of this publication and, if you can't get a copy elsewhere, I might be able to assist you in some way.<<
Tom, I know this book (which I am still trying to get from TARRC) gives a semi-empirical formula for correcting the compression modulus of a cylindrical rubber block cemented between rigid parallel plates for the "shape factor" of the block.  (I've already found that formula elsewhere.)
Just one more question about this book:  There is reputed to be a similar formula for correcting the thermal expansion of such a block for its shape factor.  I've found two references to the formula on line, but insufficient detail on the shape-factor correction.  Does Lindley say anything about this?
Failing that, does anyone have another source for this information? -- WCJ (was jclarkw)
P.S. -- If there is a way to send a personal message from one member to another through this forum, I haven't discovered it.  Any help? -- WCJ
cloa (Petroleum)
1 Jul 12 8:53
No there is no way to send a personal message- protects against marketing trolls- however you could provide your name and some secondary way to contact you such as your company website or Linkedin and someone could contact you. Email addresses are against forum rules.
WCJ (Geotechnical)
5 Jul 12 17:28
Thanks, cloa.
Close Box
Join Eng-Tips® Today!
Join Us             Close
