itzobi (Materials) |
27 Jun 12 22:30 |
Agreed with the sand cone correlation, that is a very good practice when utilizing oven dry samples. Your experience with a +0.7% solidifies what I have been saying, that the gauge gives relativly the same value as an oven/dry or speedie, give or take a %.
When we utilize our sand cone form or nuclear form to perform rock corrections for Method A or C, you end up with a rock corrected h20 content by which you back calculate the moisture out of the wet density. If the gauge back calculated for say 50% rock, it would read a value of basically half of the oven/dry value, which it doesn't, but that is what is being purported.
This is the heart of the debate, what is being said is that the nuclear gauge automatically does this already, which from my studies, I have shown that it is usually closer to an oven dry or speedie total moisture, but never close to the rock corrected moisture value, line #13 on the sheet. The only reason why the form says nuke or speedie, is in case you didn't have a speedie with you, or you were doing lots of testing and wanted to rapidly obtain a moisture value. The materials engineer believes that if I use the nuclear gauge moisture value, and correct the h20 content with a rock correction, that I am double correcting the value, which isn't true, especially if I have already obtained oven dry samples and made the appropriate offset corrections within the gauge programming.
If the gauge automatically corrected the moisture value based on the rock content, I would never even need to excavate beneath the gauge to begin with, but we all know that nuclear gauges don't do that yet.
To the first poster,
I will make some updates to this post tommorow, I believe you are referencing a different test method, both ASTM and AASHTO methods explicitly point out making corrections for oversize. I will update soon with the correct methods/designations.
Hopefully I didnt rant, and hopefully I got my point across well enough for people to understand what I am saying. |
