Select inverse
Select inverse
Select inverse
I have a bunch of stuff selected in the assembly. I would like to select the "inverse" or basically switch to everything that is unselected as being my selection set. I would like to do this because it is simpler for me to select what I don't need, if that makes any sense.
RE: Select inverse
Have you tried the 'Invert Selection' option on the Class Selection dialog?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Select inverse
John, thanks that worked very well. But now I have another problem. I will post separately.
