ANSYS file structural analysis ERROR
"The value of UY at node 279 (the node changes depending on where I put forces and constraints) i2 2.849378589E+11. It is greater than the current limit of 1000000. This generally indicates rigid body motion as a result of an unconstrained model. Verify that your model is properly constrained."
any help me?
i attached the file bellow
