Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thank you. It's already helped me greatly, and I enjoy just reading the inputs from the other members..."
Geography
nkjordan23 (Automotive)
26 Jun 12 23:13
Hello all,
I am looking for some information to help me determine the amount of contact area and pressure needed to maintain a low grounding resistance between two pieces of stainless steel that are pressed together. During temp changes, things are shrinking and expanding cause fluctuations in ground resistance between the two metals. The only reference I have found is the one below that discusses pressure (force) in minor detail. Is there any other information out there that could help me calculate these two mechanical factors?
Thanks!
http://www.deringerney.com/capabilities/ContactSel...
7anoter4 (Electrical)
28 Jun 12 9:35
There is a lot of book regarding electrical contacts.Here are a few titles:
http://books.google.com/books?id=DjnVY_UNhuQC&...
5 Jul 12 5:33
According to Holm[ Electrical Contact Handbook-1958 Ragnar Holm]
R=k/Fk^m
R[ohm];Fk[kgf]
k=7.6/10^3 ohm/kgf
m=0.8
for steel-steel bar contact.
The resistance depends upon clean state of the surfaces.
Tk-Tn=I^2*ro*pi()*sigma/32/lambda/Fk
Tk=contact temperature;Tn bar temperature far from contact point
Tk=Uk^2/8/lambda/ro
Uk=voltage drop contact across[V].
I[A];ro[elec.res.-ohm.cm];sigma=maximum material withstand pressure effort [kg/cm^2]
lambda=thermal conductivity[w/cm.oC]
Stainless steel electrical and thermal properties
CINDAS REPORT 75/77 By C.Y.Ho & T.K.Cho
http://www.google.co.il/url?sa=t&rct=j&q=s...
1 ohm.m=100 ohm.cm
1 w/m/oK=0.01 w/cm/oC
Close Box
Join Eng-Tips® Today!
Join Us             Close
