Steel pipe supports
Steel pipe supports
Steel pipe supports
Can someone give me a simple formula to calculate the amount of sag in a pipeline between to suports
RE: Steel pipe supports
Not sure there is a simple formula.
Typically, a deflection of 2.5 mm (0.1 in) is allowed, provided that the maximum pipe stress is limited to 10.3 MPa (1,500 psi) or allowable design stress divided by a safety factor of
415, whichever is less.
See page 3-7 in the following document for the formula
http://publications.usace.army.mil/publications/en...
Here is a link to an additional source. Note that formula is shown in the pdf's linked on the bottom of the page.
http://www.wermac.org/steel/pipesupports_spacing.h...
Depending on the end restraint conditions, the deflection will vary between the simple support deflection of 5wl^4/384EI, to the fixed end deflection of wl^4/384EI, with "I" being the the I of the pipe, and "E" the modulus of elasticity.
That's about as "simple" as you can get.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
I don't know if it's still available, but "Tubular Steel Structures" by the Lincoln Welding Foundation has a bit of a blurb on underground and underwater piplines that has deflection information in the chapters.
Dik
