Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...keep up the good work with this forum, I think this is the best one around. ...you actually try to help people learn for themselves. ...I commend you on providing a very good, open learning atmosphere, where usually egos are left behind..."
Geography
Hercules28 (Materials)
26 Jun 12 11:01
Dear all,
Here comes the Pickle & Passivation discussion again. Hold on tight.
I have stainless steels castings that have already been annealed and pickled&passivated.
Then I machined them with steel tooling (clamps etc). The pieces are relatively big so there was a high clamping force and whatever that entails regarding smearing or impregnating Fe particles on the surface.
I think that I need to passivate them. Does anybody else here think I also need to pickle?
In the ASM Stainless Steels Handbook it recommends just Nitric Acid for cleaning passivation. Nitric and HF is for welds.
Many people tell me that Citric acid can also be used for cleaning / passivation.
metengr (Materials)
26 Jun 12 16:31
Not enough information to respond to your question.
What is the end use of the final machined castings that would require another pickling and passivation step?
26 Jun 12 16:54
They will be used in offshore saltwater application. Low temp.
I just don't want any surprises like blooming etc..
Helpful Member!  mcguire (Materials)
26 Jun 12 18:18
Machining itself is enough reason to re-pickle if you want optimum corrosion resistance. Machining exposes surfaces which have some chromium depletion. I'm currently running a battery of tests to quantify this.
Michael McGuire
http://stainlesssteelforengineers.blogspot.com/
Helpful Member!  EdStainless (Materials)
27 Jun 12 0:37
You didn't say what the alloy was, but it doesn't really matter.
I would pickle.
What worries me about machining is the risk of smeared or folded metal forming crevices on the surface.
Plymouth Tube
Metalhead97 (Materials)
27 Jun 12 10:37
Hercules28,
Machining also works-hardens a near surface layer so if you want optimal corrosion resistance that needs to go via pickling.
MH
http://www.linkedin.com/pub/luke-autry/1b/510/566
27 Jun 12 10:55
Alloy is Super Duplex CE3MN. So all in favor for Pickling!
27 Jun 12 10:58
McQuire, why would you say that "machining exposes surfaces that have some chrome depletion?"
I would think that it exposes base metal which has 100% chrome levels.
mcguire (Materials)
27 Jun 12 11:20
Pitting initiates at inclusions because inclusion growth in the solid state causes chromium depletion next to their interface. This is the primary reason. Machining has the same effect as abrasive polishing which is demonstrably bad for corrosion resistance
Michael McGuire
27 Jun 12 15:42
Mc is correct with this. That is why when you test for intermetallics in duplex alloys you need to use a freshly ground surface. Such local defects will have been pickled out of the original surface.
Plymouth Tube
5 Nov 12 11:18
mcguire (Materials)
26 Jun 12 18:18
Mcquire did you ever finish your study?
Close Box
Join Eng-Tips® Today!
Join Us             Close
