Circular object looking like non-circluar object
This is about circular hole/object.. I've part which has so many circular objects/hole, but those are looking in octagonal shape.
I've tried making those into Circular hole with the help of View -> Operation -> Regenerate work. but doesn't working.. Can any pls help me on this?
Aj
Mechanical Engineer
UG 7.5.5.4 & TC8.3
"People can take everything from you except luck"
RE: Circular object looking like non-circluar object
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
Thanks for your response, but that is not affecting to model.. I don't see where is the Tolerance of Shaded view but I see only Stadard view. Pls refer attachement.
Aj
Mechanical Engineer
UG 7.5.5.4 & TC8.3
Then regenerate your view.
Also try pressing CTRL+F, this will fit the model on screen, sometimes solves graphical issues.
Best regards,
Michaël.
24.0 GB
Aj
Mechanical Engineer
UG 7.5.5.4 & TC8.3
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
The View - operation - regenerate does not render new facet sizes as to what i have seen.
John, Thanks for your detailed informed. Yes, whatever you're described absolutely correct. This is working fine...
Thanks all....
Aj
Mechanical Engineer
UG 7.5.5.4 & TC8.3
Also, what video card do you have on your pc? If changing those settings doesn't fix it, it may be a hardware issue.
Aj
Mechanical Engineer
UG 7.5.5.4 & TC8.3
The load options is a "separate file" and not from the customer defaults. You can scroll down and press "Save as default", when you press, read the queline to see where it got saved and in what name. Plain text file.
