Flat Pattern Additional Text
Hi guys
In NX7.5 I do a flat pattern from a sheetmetal part. After I replace the view to see the flat pattern, I add the text <W@$SH_PART_NAME> so that the file name appears on the pattern, this can then be marked during the plate cutting process.
When I do a drawing of all the flat patterns (a plate nest)I add each piece as its own view and use the model view "FLAT-PATTERN-X" but only the flat pattern data appears, not the text I added.
Even if I add the text to the FLAT-PATTERN-OBJECTS group it still does not appear.
Does anyone know how to make this work?
Munners
RE: Flat Pattern Additional Text
Did some testing and if the flat pattern & drawing are in the same file, the annotation shows through in the drawing view.
However if you are using Master Model (which I assume you are), then it is as you say. We couldn't find a way to get it to appear.
I would suggest contacting your local support office wink to get them to log it to GTAC.
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.6, NX6.0.5, NX7.0.1, NX7.5.0-> NX7.5.5 & NX8.0.0 -> NX8.0.2, NX8.5p15
