Need to drill 3 thread holes on a blind flange
I have a problem with drilling 3 holes on a 8" 300# SS316 Blind Flanges, all holes will be thread connection.
I'm not sure what code to be complied, or the calculation method.
Please advise.
Thanks in advance.
Please advise.
Thanks in advance.
RE: Need to drill 3 thread holes on a blind flange
Modifying the blind flange by placing multiple openings would seem to be a modification such that it no longer qualifies as a standard pressure component and the standard pressure-temperature ratings would no longer be applicable. Design/analysis of the modified blind flange would fall under the applicable design code (piping code, boiler and pressure vessel code, etc).
If the total area exceeds that permitted for a single hole in a blind flange, you need a hubbed blind (good luck finding one!) and you probably should do an Appendix 2 calculation per ASME VIII-1. The blind flange (in fact even the hubbed blind) will probably fail per Appendix 2 because ASME B16.5 flanges are over-bolted, but you will need to add thickness (i.e. to make a custom flange) or increase the flange class if you go the Appendix 2 route.
Petrotrim Services
www.petrotrim.com
