Drafting: monochrome automatically turns off
In drafting mode I always use monochrome display with white background. However, when changing the color of a solid (in drafting) using Edit Object Display, the monochrome display automatically turns off, showing a grey background and blue lines. So every time this happens I need to right click the drawing in Part Navigator and re-select "Monochrome". This is bothersome.
I remember once when a dialog box appeared asking me if I always wanted colors to be displayed instead of monochrome, and by mistake I clicked "yes" and "never display again".
Is there a way to reverse this? I can't find this setting.
NX8 E8800@3.7Ghz 6GB Quadro2000
RE: Drafting: monochrome automatically turns off
Preferences -> User Interface -> General
...and select the second to last button from the bottom of the dialog labeled 'Reset "Don't display this message again"'. That should do the trick.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
