reusing created catia parameter in vba
i am trying to create a visul basic code with using parameters.
after i execute the macro i can see theese created parameters under the parameters tree. also i am using these parameters for sweep operation but the sweep operation is taking only the parameter value itself. it is no more related with the parameter. how can i keep the relation between the parameter and the sweep value?
thanks
akilic
thanks
akilic
RE: reusing created catia parameter in vba
Fernando
https://picasaweb.google.com/102257836106335725208
I found how to relate feature with the predefined parameter
Set formula1 = relations1.CreateFormula("", "", hybridShapeLineAngle2.Angle, "`Prism[1-1]\Prism[1-1]_i3`")
hybridShapeLineAngle2.Angle is my angle value used in the feature and
`Prism[1-1]\Prism[1-1]_i3` is my predefined parameter.
thanks
akilic
I am after fetching parameters under part properties. Please find the code below, which will fetch all parameters in the part. (in my case there are more than 10000, which slows down the process). I want to get all parameters under "Part1\Properties\Para.1, Para.2, Para.3....etc. Any idea?
Dim partDoc As Document
Dim paras As Parameters
Set partDoc = CATIA.ActiveDocument
Set paras = partDoc.Product.Parameters
For i = 1 To paras.Count
MsgBox paras.Item(i).Name
Next i
Please find attached screen shot.
