Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have tons of books, have book marked tons of tutorials, which have helped, but this forum has answered those "impossible to find" solutions. I am thrilled with this site..."
Geography
egebull (Chemical)
25 Jun 12 16:12
How can methane solubility be calculated in NGL? Is there any process engineering simulation program (like HYSYS, Promax etc.)can be used to calculate how much CH4 can be absorbed in NGL if residue gas, which is mostly methane is used as blanket gas?
Oz
PaoloPemi (Mechanical)
26 Jun 12 2:39
I think a EOS as Peng Robinson or Soave Redlich Kwong (extended versions if your mixture includes some little percentage of heavy or non-hdrocarbon components) should give reasonably accurate results, these models are included in almost all commercial software,
by the way I use a process library (Prode Properties) with Excel for these calc's.
MortenA (Petroleum)
26 Jun 12 8:34
NGL is not a precise term. But yes - any descent process model such as HYSYS will calculate how much C4 you can re-absorb into the NGL. The amount will of course depend on the P/T than you will have your NGL at.
Consider that a destillation tower is a contineous series of equilibrium stages. So at the bottom stage the NGL is in fact in equilibrium with C4 in the gas phase. But the amount of C4 in the gas phase is then a result of an equilibrium on the stage above in the liquid stage and so forth.
Best regards
Morten
dcasto (Chemical)
5 Jul 12 17:22
I can tell you answer without a simulator. MORE THAN ENOUGH TO MAKE THE NGL OFFSPEC. Do not ever use methane as a blanket gas on an NGL stream. Been there, done that, shut the valve, got the bonus.
Close Box
Join Eng-Tips® Today!
Join Us             Close
