Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Over the past year I have found your site to be EXCELLENT. Never have I been able to find so many answers to such vast problems and it is an excellent service..."
Geography
AMChroma (Mechanical)
25 Jun 12 15:21
I used Autodesk Inventor LT Task Scheduler to convert a .idw to a .dwg, and then attempted to open the .dwg using DraftSight, assuming it would work as it usually does. However, DraftSight gave me an error: "This version of drawing file is not supported" "Unable to open file". Does anyone have any idea what may be causing this?
If system information is relevant, this is running the latest version of DraftSight, on a Windows XP Professional 32 bit system. Let me know if I can provide any more relevant information.
Helpful Member!  PatCouture (Mechanical)
27 Jun 12 9:44
I don't know if draftsight is always able to open the latest file format from Autodesk, maybe they are a version behind because of the programming required!
I'm just guessing here though.
Patrick
27 Jun 12 9:54
You were right, I tired saving as a Autocad 2010 .dwg, of all things, and draftsight was able to handle that. Anything after 2010 seems to be incompatible with draftsight. Thanks!
Close Box
Join Eng-Tips® Today!
Join Us             Close
