Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I love the structure of the site. You start at the top, and drill down to what you want. Maybe I've been using Unix too long... :-) "
Geography
uasteelcrete (Civil/Environmental)
25 Jun 12 13:50
I'm laying out the installation of some new equipment on an existing slab and plan to use Hilti HY 150 max adhesive anchoring system. I'm using a 1/2" threaded rod (HILTI HAS E-Rod)with an embedment depth of nine inches. I'm using HILTI's design charts and formulas and checking that it corresponds with ACI 2012. I'm also considering the spacing and edge distances. Does it sound reasonable to calculate an allowable tensile resistance of 9,000 lb per anchor and an allowable shear resistance of 4,500 lb per anchor with an adhesive, 1/2 inch threaded anchor embeded 9 inches? I'm confident with my calculations and process it just seems high to me for some reason.
Ron (Structural)
1 Jul 12 21:25
Keep in mind that you typically will need a safety factor of 4 with adhesive anchors in tension.
ornerynorsk (Industrial)
5 Jul 12 13:30
http://www.designnews.com/author.asp?section_id=13...
Related, but it sounds like you're working with gravity (slab install vs suspended install) instead of against it.
Close Box
Join Eng-Tips® Today!
Join Us             Close
