interchangeability of pitot probes ?
Is it possible to use pitot tubes of others manufacturers on a diffmanometer (flowmeter)? For instance - Dwyer pitots with Testo manometers ?
RE: interchangeability of pitot probes ?
Yes.
Thank you !
I wouldn't unless you check their construction.....difference in geometry will cause difference in readings.
Yes, should be so. Although some brands' data sheets state theirs meters "work with almost all tubes", the most of the others do not.
