imported JT file saving
Okay, so I am using NX7.5 and this should be a basic setting change. My company has a dual CAD platform where we use NX and I-DEAS (phasing out I-DEAS). Anyway we use JT files alot and basically I need to import JT files into an NX assembly and then save it. Well this should be fine but when I save it, NX prompted me initially that not all JT data was associated and if I would like to export it. I checked yes and "Do no not display again". Well then NX stars prompting me for every parts material and there are tens of thousands of parts. I do not need to save this information, is there a way to reverse this? Attached is the pop up I don't want to click a million times. I know this is probably a quick fix but it is truely annoying. Thanks.
Design Engineer, NX 7.5
