ANSYS WORKBENCH, how to simulate 4 sling supports on a frame?
Hi!
Im doing a static structural ansys WB analyse of a square frame. I imported the model from solidworks, but not with the 4 slings holding the frame up. Is there any tip on how to add supports in the 4 corners of the frame to simulate the 45 degrees slings(see photo).
-Hank
-Hank
RE: ANSYS WORKBENCH, how to simulate 4 sling supports on a frame?
However, i would be much appreciate with a more spesific workbench tip since im not that good in workbench yet.
You'll find all the support / "fixing" options in the Analysis Settings of Mechanical.
