Regulate Incoming Steam Pressure
We have steam from coal-fired boiler and steam from waste heat boiler of sulfuric acid plant, all connected on a common header. The problem is, the pressure of steam coming from the coal-fired boiler is fluctuating and is almost always < 42ksc, while that coming from the sulfuric acid waste heat boiler has a pressure of 42 ksc. how can we regulate the pressure of steam coming from coal-fired boiler given the ff conditions:
-boiler feed cannot be incresed
-pressure regulation is to be done on the piping system only
This is my proposal, attach a pressure regulator valve at the steam line of coal-fired boiler that if pressure is < 42, then steam will be redirected to the existing desuperheater and be converted to low pressure steam. This is just an idea, I don't have details yet as to what % oopening of the valve should be normally operated, etc.
Any help is welcomed..
RE: Regulate Incoming Steam Pressure
I'm not really clear what your problem is. It sounds like you think diverting part of the boiler's steam production to the LP steam header will raise the supply pressure?
what should be done?
I'd start by trying to understand the system's hydraulics to identify why there is a 4 bar pressure drop between the sulfur plant's waste heat boiler and your turbo generator under some scenarios. It may be that you are just trying to move too much steam between those two locations for the size of the line you have (I had asked if there was a letdown valve at the waste heat boiler which you agreed with, if steam is going through the letdown valve it's not flowing down the main steam header). If the pressure drop is due to the amount of steam you are trying to move through the existing pipe, you would need to install a larger or a parallel steam header to reduce the piping pressure drop over the section or sections in question.
Try to get some data to see what the pressure profile is and does that match what you would expect based on your calculations.
In theory if the coal fired boiler steam drum is connected to the 42 kg/cm2 header, then it always has to operate at slightly above 42 kg/cm2 pressure. Unless of course there is a back-pressure controller in the system.
I would look more at why the coal boiler cannot produce steam at the required pressure than adding another layer of control.
Secondly, I would look into if it's absolutely necessary for the turbine generator set to require exactly 42 kg/cm2 steam and not 38 kg/cm2 steam (that is a reasonable operating range).
I would assume that from the combined 42 kg/cm2 header steam is letdown as needed to the other plant users and that the excess 42 kg/cm2 steam is fed to the turbine generator set.
To me it doesn't make sense to have the coal boiler let down into the low pressure header system, unless the coal boiler rate matches the low pressure requirements. It might be you want to fire the coal boiler to maximum rate to generate as much electricity as possible.
GOOD LUCK!
thank you very much.
Good luck.
I'm with Mr. Hartman. There is something wrong with the firing rate controller or the combustion control system that allows the pressure to fluctuate.
Does the turbine load fluctuate? Maybe the controls are set up so that the waste heat boiler is allowed to produce uncontrolled and the coal fired boiler is taking the swings that varying turbine loads create, if its load is variable. You may need to add some feed forward controllers to anticipate load swings and give a rate kick to the coal fired boiler.
Sounds like a situation where the tail is wagging the dog.
rmw
