venting of pipelines
Hello to all;
We have a GRP underground pipeline for sea water transportation. Because of clash with another pipeline, a portion of pipe moves up and after a couple of meters moves down in the previous elevation, and therefore makes an air pocket in the line. Naturally we need a vent hole on the top of the elevated pipe for hydrotest. The question is: do we need this vent hole for venting of air before transportation of sea water? I mean can accumulation of air obstruct the pipe?
RE: venting of pipelines
When a line is liquid-full (disregarding friction) the pressure at a given upstream elevation will be the same as the pressure at the downstream of the hill at the same elevation. If the line is not liquid full, then the pressure at the upstream bottom of the hill will include the hydrostatic head of however much liquid is in the upstream leg (usually pretty close to the height of the hill). The pressure at the bottom of the downstream leg will be less because the downstream leg is farther from full. Sometimes the pressure at the bottom of the downstream leg will be very low for a significant hill.
Bottom line of all this is that if you are just jogging a few feet to get over the foreign line in pretty flat country then you are not going to see a huge problem. It can be big if there are significant elevation changes.
To evaluate the net effect of multi-phase flow, I generally get very close to actual conditions by doing a 4 step process: (1) calculate the single-phase pressure drop in the line (for gas I use the Isothermal Gas Equation, for liquid I use Darch-Weisbach); (2) calculate the 2-phase friction using Duckler (see GPSA Engineering Field Data Book); (3) I use the Flannigan Correlation to get the dP due to elevation changes; and finally (4) I add the three dP's together and am always within 20% of observed conditions (better than the high-dollar multi-phase flow models generally do). The second step for you probably isn't applicable since you don't seem to have much gas. The third step is important for your process. It is also described in GPSA. In this step you add together all the up-hill portions of your line traverse (disregard downhills). It can result in a big dP. In your case if the dP is more than you can tolerate put in the vent. If not, ignore it.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
Manual air release valves are sometimes required during the initial startup of a water pipeline to allow the air to be released. After the initial air release, the valves are generally not required. Automatic valves should be used only as a last resort. Automatic air release and vacuum valves have been used on steep grades to prevent the collapse of thin walled pipe during a fast drainage during an emergency.
The correct term for the flow obstruction is air binding. Air binding may occur is the design of the pipeline system is inadequate. Designing the pipeline velocity to more air down the pipeline is usually the most attractive design approach. The velocities required are within the normal design range for transmission pipelines.
You have not presented actual the actual design condition so I have included some references to allow you to under the issue.
I don't do water pipelines, but that certainly is not to my understanding, and most certainly not what the air valve manufacturers say. Their theory is that water can always contain a high content of air in solution that becomes free air due to temperature and pressure changes, making the air valves a continuous necessity for the lifetime of the pipeline.
If it ain't broke, don't fix it. If it's not safe ... make it that way.
The use of air valves and relying on air valves is risky because of uncertain maintenance. Designing the pipeline velocity to more air down the pipeline is usually the most attractive design approach. The velocities required are within the normal design range for transmission pipelines. The velocities are identified in the linked document.
You'd think that water pipeline engineers would catch on, but looks like they have not.
Thanks.
The trouble I have with steam-trap style air eliminators is that they always spit some water with the air, sometimes a lot of water. The pipe around them is always nasty and covered in rust. I've never seen a pipe failure from this surface corrosion, but I've had several clients that were really worried about it. I've got a provisional patent on a device that captures the gas for use, but it really only makes sense then the gas is a saleable product, it is too expensive for low-pressure air.
David Simpson, PE
I am not saying that air release or vacuum valves are never required, just that you should try not to minimize the use of them. If you have a real steep high point, an air release may be required.
