Abaqus 6.11/Shell: Detect reaction force and reapply to opposing side
currently I am working on a FEM model in Abaqus 6.11 which simulates the stress and strain in a conveyor belt. To make the simulation easier I reduced the problem to a two dimensional model. To do this I "cut" the belt and have the carrying side and return side of the belt forming a rectangle. On this rectangle I apply a shear force (see my other post) which causes the belt to stretch.
As a boundary condition I have to have the opposing sides of the shell behave as if they have not been cut before. I have been trying to solve this problem by applying kinematic constraints but this leaves me with other difficulties such as missing boundary conditions for the movement in space.
Thats why I have been thinking about boundary conditions that would detect the reaction force RF1 in the fixing an reapply this force in every step to the opposing side during calculations. A attached sketch demonstrates the idea.
I could not find any help on this before so I would be very thankful for your help.
RE: Abaqus 6.11/Shell: Detect reaction force and reapply to opposing side
I think you can do it with sensor output and user amplitude (UAMP/VUAMP).
Detail information you can find in Abaqus documentation:
Abaqus Analysis User's Manual, 4.1.3 Output to the output database, Sensor definition
Abaqus User Subroutines Reference Manual, 1.1.19 UAMP User subroutine to specify amplitudes.
Bartosz
Hello Bartosz,
thank you for your help on this. I will try to realize it as you proposed.
My previous erperience was that a sensor can only report properties that are assigned to one node. I thought of a solution that would capture the reaction force at the entire cross section and then reapply the force to the corresponding nodes on the opposite side.
I will let you know how it worked out.
