CATScript - How to Pass a variable to another CATScript
I am using CATIA.SystemService.ExecuteScript to execute a vbs from within a CATScript. I see there is a param at the end which I am assuming can be used to pass a variable to the other script. However it seems to be defined as an array and I don't understand how I push my variable into it and use it in the called vbs. For the record the variable I am trying to pass is the path of a CATIA Document.
Jeff
