Solenoid operated valve
I have need for a solenoid operated hydraulic valve that will allow the pump to bypass directly to the tank and hold the cylinder in the correct possition when not in use.  I had thought that a 3 position open center was what I needed.  Now after looking at the cataloges, I may need a tandem valve.  It appears that the open center will allow the pump to bypass to the tank but may not hold the cylinder in position.
Any help?
Thanks in advance.
Kevin Kidd
KK Broadcast Engineering
kkidd@kkbc.com
RE: Solenoid operated valve
Do you have a fax number?.....I can fax you some examples that might work.
David Baird
dbaird@gemcity.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
