Hipot leakage current
Does anybody know of any standards for specifying maximum leakage current during end of line hipot tests? This would be for low voltage motors (460V or less). UL 1004 specifies a hi-pot voltage but not the leakage current. Perhaps there is an IEEE standard?
RE: Hipot leakage current
For ac, there is not even diagnostic value to measuring current (unless you also get a phase angle). That is because there is high capacitive current that overwhelms any true leakage current.
For dc, there can be some diagnostic value to plotting leakage current vs voltage which voltage is increased in a particular step or ramp fashion. See IEEE95.
(2B)+(2B)' ?
There is a selector for the meter display range.
There may possibly be an adjustment for the test set overcurrent trip point lower than the max level required to protect the test set.
(2B)+(2B)' ?
http://www.phenixtech.com/9-ACDportables.asp
One point you should believe: the results of a ac hi-pot test with corrrect hi-pot machine settings (*) should not depend upon the settings of the hi-pot as long as voltage is at specified level. * In other words, don't set the trip so low that it will trip for a normal motor. Once the ac starts to increase above the normal capacitive current for the motor, it will surely increase rapidly to the trip point, regardless of the trip point.
(2B)+(2B)' ?
