Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks a lot Mate! I can't tell you how many times your site has saved my "rear". hehe..."
Geography
How to save SpaceMouse-3Dconnexion button assignments?
Tingsryd (Industrial)
22 Jun 12 9:32
I am running 3Dxsoftware 3.7.22 on Win7-64 with an old Spacemouse Plus. It's an unsupported configuration but it works fine.
I am in the process of migrating to 8 and my question is: is it possible to save my button assignments so I can use it for a fresh install of 3Dxsoftware?
The button assignments are separate for each application so I'd like to save them; if I have to re-do all of them it's not the end of the world but it would save some time as well as being able to copy it to multiple workstations.
NX7.5.5
NX8.0.2
JohnRBaker (Mechanical)
22 Jun 12 12:29
While NX is running, have you tried to open the '3Dconnexion Control Panel' dialog (usually one of the buttons on the 'spacemouse' will have been programmed to do that or you can always go down to the little pop-up panel on the Windows area at the bottom-right side of the display and double-click on the '3DXware' icon)? Once this dialog is open, under 'Options' you can explicitly save your current configuration. Of course, once you go to a new driver I'm not sure that it will allow you to upload a configuration saved from a different and now, as you say, obsolete device, but you have nothing to lose trying.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
22 Jun 12 19:24
Tried it but no luck; there doesn't seem to be a way to save the configuration outside of 3Dxware.
NX7.5.5
NX8.0.2
jerry1423 (Mechanical)
25 Jun 12 10:14
In my 3DConnexion Control Panel there is an Options pull-down with a Save-As command. I think that should do what you want.
25 Jun 12 10:53
Thanks Jerry. I tried that but it seems it is only for saving configurations internally.
NX7.5.5
NX8.0.2
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
