Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...with companys cutting back on training, lack of true support by makers of software, the forums are a great tool in your cyber-toolbox...."
Geography
rbhall (Civil/Environmental)
22 Jun 12 6:54
I was recently ask can you install fire dampers in a wood floor joist system. The building is old and is having a change of occupancy that requires the floors to be rated between the 1st and 2nd floor. The membrane is 3/4" plaster on the ceiling side.
UtilityLouie (Mechanical)
22 Jun 12 10:16
This is a big "it depends" answer.
You first need to make sure the whole floor assembly is a rated assembly. If it is without upgrades, you should be able to install the fire dampers in the floor if that specific fire damper has been rated by UL to be installed horizontally in a UL rated floor assembly.
My experience with fire dampers is that as long as it is UL rated in the way you want to use it, there are no issues. This may require extra framing around the opening, but that shouldn't be a huge deal.
I really think your biggest issue is the fire rating of the existing floor construction. You may need to add fire rated drywall to get the fire rating you need.
DRWeig (Electrical)
22 Jun 12 11:33
You might consider red-flagging this one an re-posting in the NFPA (fire) Code Issues forum. There are some experienced inspectors who prowl that forum.
Good on ya,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Wareagl487 (Mechanical)
12 Jul 12 7:47
In my experience, installation in rated wood assemblies are accomplished by using radiation dampers in lieu of fire dampers. Much less of a hassle installing them in thin assemblies.
12 Jul 12 7:48
Close Box
Join Eng-Tips® Today!
Join Us             Close
