Trim a sheet by projecting splines
In the attached model, there are 3 splines (23, 24 and 28) I have added continuity to spline 28 so that is touches the other 2 and I would now like to use the trim sheet command to trim swept (6) in the Z axis. Now I would have thought that I could use selection intent along with follow fillet to pick the splines and trim the sheet, however it seems as though it doesn't want to play ball. I don't want to project the curves first, and I don't want to have to trim the spines, I jsut want to use them as they are and trim the sheet and more importantly understand why they won't at the moment.
Any help would be greatly appreciated.
Cheers
Si.
Cheers
Si.
Best regards
Simon NX7.5.4.4 MP5 - TC 8 www.jcb.com
RE: Trim a sheet by projecting splines
Best regards
Best regards
