Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Compliments on a fantastic web site. I have learned so much from my threads and even if sometimes I cannot solve the problem, it gives me the reassurance that I am not the only one putting up with it!..."
Geography
Riversidean (Civil/Environmental)
21 Jun 12 14:39
This may be a very simple question, but I am looking at creating an alignment for an 8" HDPE SDR 17 pipeline. I am trying to keep to the angles used by pipe fittings, but in some cases I get a 40 degree angle rather 45 degree angle. Is there anywhere I can for formulas for pipe bending after a fitting? Should I should assume the minimum turning radius (I have that formula) for a pipe the pipe after the fitting?
P.S. I have plenty of room for the pipe to turn...
Thanks...
racookpe1978 (Nuclear)
22 Jun 12 3:34
Get a 45 degree elbow.
Get a bandsaw large enough to pass the 8 inch dia pipe.
Cut 5 degrees off.
Reprep the joint.
22 Jun 12 5:17
To correct/audit myself: If you are trying to "force" a 40 degree bend through a 45 fitting with a solvent-welded type joint, you will likely fail.
If you can't adjust your start or end points to accommodate a real 45 degree elbow, try inserting a 90 elbow, with the outlet aimed "vertically" up from your x,y plane.
Add a stub lenght of vertical pipe, then another 90. But this puts the second 90 directly above your starting point, except the second 90 CAN be rolled to the 40 degree you want. (Or any other angle actually)
Run the straight pipe from that elbow, now "lifted" in z by the 2x 90 elbows to the desired end point at the 40 degree angle you demand, then add two more 90 elbows.
The first to aim "down" and the second to resume the direction you want.
OK, you've solved one problem, but you have increased fabrication time, material cost, and the flow resistance
austsa (Mechanical)
22 Jun 12 6:37
8" HDPE SDR17 pipe should be able to flex 5 deg very easily .... especially considering that you have plenty of room.
dicksewerrat (Civil/Environmental)
23 Jun 12 20:51
Why don't you order a 40 degree bend in your 8 inch and whatever SDR and electrofuse it?
Richard A. Cornelius, P.E.
WWW.amlinereast.com
BigInch (Petroleum)
24 Jun 12 1:20
Check the minimum radius, then use the maximum you can fit into the space available ... or less, as you may decide to leave space for future installations.
If it ain't broke, don't fix it. If it's not safe ... make it that way.
Close Box
Join Eng-Tips® Today!
Join Us             Close
