CATScript - InputBox Size
I am using InputBox to list all the parts loaded in a CATIA session and allow the user to select one to perform an operation on. If I have more than 33 lines, the list is truncated and I cannot see the other files. Is there a way to control the size of the dialog box so I can see all the files? Maybe the option of a scrollbar, or...??
Jeff
Jeff
RE: CATScript - InputBox Size
Jeff
Not in CATScript, you have a lot of limitations here...try VBA if is available.
Fernando
https://picasaweb.google.com/102257836106335725208
