Super Hydrophobic Spray ON?
I am looking to create a super hydrophobic solution for painted metal surfaces (stainless steel, car paint, etc.). I know that there was a thread posted about this in 2010, and it was incredibly informative.
Certain Trichlorododecylsilane elements are hard to find, and I would like to make a transparent solution to apply to certain substrates. Please let me know if anyone can help!
RE: Super Hydrophobic Spray ON?
Thank you for the reply. Do you know the best way to contact him? I would be more than happy to reach out to him and see if we can come to terms. I understand that the technology exist currently for superhydrophic application. However, I am looking to get the specific formulation that is "eco-friendly" - chlorine based or fluoro based - spray on polymer that can provide 6 month protection. I have used several different mediums, and I cannot seem to get the proper formulation (either semi-transparent with toxicity too high, or transparent but destroyed upon touch). Please let me know if you know how to reach demon3 as he was the person that appeared to be very privy to this topic. Cheers
PS compositepro. Thank you for the response, but rain-x is specially formulated for windows and ethanol traits can tamper painted substrates on a molecular level damaging gloss effects. I would like to create something specifically for my application. I have used several silanes including trichlorosilane and i am trying to use teflon (PTFE) as well. Again, I know that similar technologies exist currently, but I am looking for something ultra/super hydrophobic as seen in Daikins polymer here : http://www.geek.com/articles/mobile/superhydrophob...
Demon3's sig line is as follows, I'd try reaching him via his website:
Chris DeArmitt - PhD FRSC CChem
Plastic & Additives Webinars
Instant Downloads & Inexpensive
www.plastictraining.com
http://www.cytonix.com/classic/fluoropelsuspension...
I have not tried this, but it appears that this would create a milky translucent finish in lieu of completely transparent or glossy finish. This would be perfect if there were a transparent effect by spray application.suggestions?
Ben
I used trichlorosilanes because they are much more reactive than the above. You should not use alcohols as solvents for them because they will react with the alcohol to make products that react less well with your surface.
Thanks again
Take a look over in the paint/coatings forum, there is a guy there asking about a clear/opaque transitioning polymer. I seem to recall you had a patent on one such idea?
Chris
