how to create helical spring with both ends washed
NX6.0.5.3 .. Can try with NX8.0
Need the Idea on how to create coiled helical spring with both ends washed.. I had seen the demo in 2012 PLM conference by Mr.John Baker..
He did it in NX8.5..
RE: how to create helical spring with both ends washed
However, starting with NX 8.5 you can now create the complete spring using only single law controlled Helix which makes it very easy to edit any aspect of the model.
Attached is a zip file with an NX 8.0 version of both a 'Simple' and a 'Closed End' spring as well as a video showing how you'll be able edit an NX 8.5 version of a 'Closed End' spring constructed as described above.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I think people will find that irrespective of what approach they've used in the past, if what they're trying to model uses a Helix, that they will now have all of the controls that they could possibly need to get the job done in ONE easy to understand and use function.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Insert -> Sweep
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
