Linked body not moving with parent body
Hi all,
I am on NX 7.5.
I have an assembly part, for simplicity lets say there are 2 components. A shaft with a flat, going through a block with a hole. There is an assembly operation needed in which a hole needs to be drilled through the block and shaft on assy. Therefore I created a wave linked bodies of the shaft and block allowing me to create a hole going through both components.
Also the shaft needs to be shown in 2 positions rotated along its axis, lets say flat horizontal and flat vertical. So I create 2 arrangements and arrangement specific assembly contraints (2 different angles of the flat).
My problem is that when I toggle between the two arrangemnts the shaft component rotates but the linked body I made from the shaft does not. How can I make the linked body move with the body its linked to?
Rich
I am on NX 7.5.
Rich
RE: Linked body not moving with parent body
John Lackowski
NX Support
Win 7 64bit NX 7.5.4.4 TC 8.3.1.1
http://cad-unigraphics-projects.blogspot.com/
Cheers
Can someone confirm if what I want is possible?
Cheers
This will cause the geometry to update, but not position when the parent is edited. These are great for linking parts into tooling designs, but are not good for system designs where parts are expected to react upon edit.
I did therefore try using the assembly cut instead, ( sounds like your case could use this option ) and it does update.
Tomas
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
