ABAQUS PDE problem
ABAQUS PDE problem
Hello colleagues!
I'm having this weird problem in ABAQUS, every time i try to open the PDE interface, abaqus crashes and shuts-down. I never had this problem before ... i searched simulia page for possible solutions and the ones i've found so far are to modify abaqus graphics environment file which i already tried to do, but problem is still there. This is was my procedure:
1) changed the name of old graphicsConfig.env file
2) download and saved new graphicsConfig.env to the same folder
the only thing i haven't done was reseting permissions on graphicsConfig.env file... the command "% chmod 644 graphicsConfig.env" didn't work...
here is the error message from abaqus:
atxCaeSvr.ipcStart(True): <class 'socket.error'>: [Errno 10049]
Unexpected error 193
ipc_CONNECTION_BROKEN
Abaqus Error: Abaqus/CAE Kernel exited with an error.
any ideas on how i can work this out?
Thank you
Thank you
RE: ABAQUS PDE problem
http://www.eng-tips.com/faqs.cfm?fid=376
Thank you
I think it had something to do with the proxy i was using to connect to college wireless lan... try to close or allow abaqus thru your firewall, see if you're using any proxy servers... i also found this on the web: http://forum.cadec-online.com/viewtopic.php?t=5&am... try it to see if it solves your problem.
Cheers
