Looking for material aisi 4145 properties
RE: Looking for material aisi 4145 properties
4145 is simply a composition spec, which is now defined as UNS G41450. This is well defined (the UNS book is SAE HS-1086 or ASTM DS-561). As for other properties, they will be dependent on heat treatment and product form. The UNS book cross-references to applicable specifications for a number of product forms, but you will have to do the homework to find out which is applicable for your situation.
Aaron Tanzer
www.lehightesting.com
Hi Aaron,
Thanks for the update.Im specifically looking avaialble specification in the AISI 4145: Oil hardening alloy steel , Please let me know where i can get a chance view the complete inforamtion about the standard.
Kiran
You can view this data here:
http://books.google.com/books?id=boKzK-u2MoIC&pg=P...'s+guide+aisi+4145H&source=bl&ots=_LqjClSZsE&sig=g4hJy2mRUuS-uEQuic6t2nvFkWM&hl=en&sa=X&ei=A8LhT9GVObSn0AGM9IieAw&ved=0CFsQ6AEwAA#v=onepage&q&f=false
For whatever reason this website doesn't highlight the entire link, so you'll have to copy and paste it into your browser window. I would recommend purchasing this book from ASM International or from Amazon. It's an extremely useful book for finding this type of data for a wide variety of common (and not so common) materials. The link to the book on the Amazon website is here:
http://www.amazon.com/Heat-Treaters-Guide-Practice...
You might find it for a reduced price on the ASM International website.
Maui
www.EngineeringMetallurgy.com
Thanks.
Is it possible any way to view the original standard other than what is found in Heat Treater Guide.
Im in project, where i need to collect and compare the available standards with respect to supplier data.
Kiran
You will need to purchase the standard if that is what you specifically need.
Maui
Ok Maui,
Thanks for the inforamtion.
Kiran
kiranengr,
You may try and visit any library near your city,you sure will be able to get the information.
If you are in a project,surely there must be funds for purchase of books and technical material.
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
