Saw Cuts in Slab on Grade
How soon after pouring should saw cuts be made in a slab on grade? The slab is 4" thick and is being poured in Florida.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Saw Cuts in Slab on Grade
FAQ592-162: What causes random cracks in floor slabs.
Agree with both. With a 4" slab make sure thickness is tightly controlled or thickness variations will create their own control joints... otherwise known as random cracking.
See the FAQ above for more info
This cannot be stressed enough.
It’s no trick to get the answers when you have all the data. The trick is to get the answers when you only have half the data and half that is wrong and you don’t know which half - LORD KELVIN
