Where is SA-182 Gr. F11 Cl. 3?
Can anyone tell me why SA-182 Gr. F11 Cl. 3 is listed in ASME Section IX & II Part A but not listed in the stress values tables in Section II Part D, B31.1 or B31.3?
RE: Where is SA-182 Gr. F11 Cl. 3?
Because this material is not an approved material for pressure boundary applications with stress lines.
BTW; did you check if this material can be used under a code case?
