cost difference between WF and HSS
Could anyone shed some light on the current price differential between a wide flange shape and HSS square/round shape? how about the connection cost difference?
Thanks.
Thanks.
RE: cost difference between WF and HSS
HSS is cut from rolled sheet or maybe coil, folded or otherwise formed, and then welded along its length. It's inherently a more expensive process.
... but local market conditions affect the price of each product separately, so you may find cheap HSS or be forced to buy expensive WF.
There are other differences between otherwise similar Wf and HSS products that may be important to your particular application, or not:
- HSS is much stiffer in torsion.
- HSS can be more difficult to protect from corrosion. Painting the interior is difficult; inspecting the paint is impossible. You can plug the ends with weld if you don't need to use the lumen.
Connection costs are more difficult to compare. Aircraft designers will tend to use a fatigue= resistant joint on HSS shapes, comprising a plate in a slot. Oilfield guys will miter the HSS ends and seal 'em up.
Mike Halloran
Pembroke Pines, FL, USA
Best regards.
