ATFP window stuff
ATFP window stuff
thread507-268076: How to trasform blast load to static load
Note that there is a new UFC out for ATFP. Does anyone know how to interpret B-3.1.4.1 with respect to the tributary area increase factor? My only guess as to what this means is that the whole wall should be loaded with blast pressure just like wind. Meaning the trib increase factor on the supporting elements makes the load on the supporting element include the reaction from the window?
If this is the correct interpretation, then how should the load be calculated? Should we just use astm f-2248? That's for glazing.. There's a blast pressure equation in NCMA TEK 14-21 for peak blast pressure, but peak pressure is waaaay higher than equivalent static pressure. Also, using astm f2248 for the whole wall would be conservative because most wall structures would be waaay more ductile than glass.
Also, does anyone know how the 3-second equivalent design load in ASTM F2248 was created? Are there equations?
RE: ATFP window stuff
