Condition Monitoring Locations
Hello all,
I'm attempting to develop a loose outline for a Mechanical Integrity Progam. The API and ASME literature is good but it doesn't give even basic guidelines on how to determine locations/patterns of Testing and Condition Monitoring Locations, it just says to consult an expert. There is an endless slew of books and papers on the subject but I don't want to waste the money buying something that's just going to tell me to 'consult a corrosion specialist to determine Condition Monitoring Locations' as the API Standards do. 'Corrosion Inspection and Monitoring' by Pierre Roberge looks promising, does anyone have any ewxperience with it? Any and all help is much appreciated.
RE: Condition Monitoring Locations
Thank you SJones, that filled in a lot of blanks. I'm wondering if you know of any literature that describes a baseline for inspection locations? For example, I'm looking for something like:
'During inspection, perform [NDE Method] test every ____ meters for the length of the pipe'
The goal is to establish an excessive amount of inspection points then compare them to previously acquired data and determine which points are unnecessary based on low corrosion rates and eliminate them. I know this kind of specificity is dependant on many parameters (fluid flow, acidity, construction material, etc.) but I'm wondering if there is a general model to be applied. Thanks again for your post and any future help.
The goal is to MINIMISE inspection and only increase it if warranted. You will never get a standard stipulating what you are seeking - it's all down to risk assessment and engineering judgement coupled with functional data management and interpretation. This is why 'experts' are needed!!
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Expert; Ex- a has been, and pert is a drip under pressure.
