Minimum L/D for DarcyûWeisbach equation
Is there some value of L/D for which the Darcy–Weisbach equation is applicable?
At what point does 'relative roughness' become meaningless?
Is there any expectation of accuracy in calculating the pressure drop through a 10-foot steel duct that is 5 feet long?
Seemingly not because the flow is not close to "fully developed" in such a short length.
For such a short duct, how meaningful are the friction factor based on e/D (in this example = 0.15/10 = 0.015) and the pressure drop based on L/D (in this example = 0.5)?
If using an orifice equation, what is an appropriate value for C_d, coefficient of discharge for the incompressible flow equation in Wikipedia:
http://en.wikipedia.org/wiki/Orifice_plate
Or is some other calculation more appropriate for this situation?
RE: Minimum L/D for DarcyûWeisbach equation
For a conduit between reservoirs I don't imagine the flow is fully developed if L/D < 10. There may be a better limit, but I suppose L/D = 0.5 for a conduit between reservoirs isn't even close to an appropriate application of the Darcy–Weisbach equation.
Thanks.
