Flat patterns
Flat patterns
Flat patterns
NX4 was so easy to create flat paterns in sheet metal, what is an easy way to do it in NX7.5.
Tanks for any help.
Andy.
RE: Flat patterns
see added image.
Do note that the part you wish to make a flat pattern of has to be a sheet metal part. If it's not, you can use the 'convert to sheet metal' button somewhere in there as well. (use the command finder if you can't find it).
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
