Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site was well structured and I found what I was looking for in about 2 minutes. I am looking forward to participating with you in the future..."
Geography
anicefob (Chemical)
18 Jun 12 17:14
thread1036-309842: Need Excel Calc for Linepack Calculation
Thanks to linepacker for the VBA for calculating the supercompressibility factor. There are some minor errors in the VBA code & points for those wishing to use it.
1) You need to replace
nx19_Padj = (156.47 * nx19_Ppsia) / (160.8 - (7.22 * SG) + moleCO2 - (0.392 * moleN2))
with
nx19_Padj = (156.47 * Ppsig) / (160.8 - (7.22 * SG) + moleCO2 - (0.392 * moleN2))
This is because nx19_Padj is supposed to be in psig. Also, not doing it would result in double counting of the atmospheric pressure (14.7 psia) when computing the variable nx19_Pii
2) You need to replace
nx19_fpv = ((1 + (0.00132 / nx19_Tao ^ 3.25)) ^ -2) / (((1 / ((nx19_B / nx19_Dp) - nx19_Dp + (nx19_N / (3 * nx19_Pii))))) ^ 0.5)
with
3) The VBA code provided is only valid for a certain range of temperature & pressure when the E equals E2 (and not when E equals E1, E3, E4, E5a, E5b, E5c, or E6). You will need to refer to the NX-19 document to incorporate these into the code.
Thanks again to Linepacker (errors notiwthstanding)
Enjoy!
Helpful Member!  anicefob (Chemical)
18 Jun 12 17:17
CORRECTION in above:
with
nx19_fpv = ((1 + (0.00132 / nx19_Tao ^ 3.25)) ^ -1) / (((1 / ((nx19_B / nx19_Dp) - nx19_Dp + (nx19_N / (3 * nx19_Pii))))) ^ 0.5)
dcasto (Chemical)
21 Jun 12 14:09
here is a simpliar method for compressibility of natural gases with under 4% inerts
Tc (critical temperature) =169.01+314.001*Spgr where spgr is specific gravity
Pc (critical Pressure) = 708.75-57.5*Spgr
Pr = PSIA at conditions / Pc
Tr = T (rankin) at conditions / Tc
z = 1 + (0.0703 *Pr / Tr) * (1 - 6 / Tr ^ 2)
At 60F and 1000 psia on a .6 spgr gas, z = .8682
BigInch (Petroleum)
21 Jun 12 16:59
If NX-19 is the subject, simpler methods are of no interest.
If it ain't broke, don't fix it. If it's not safe ... make it that way.
BigInch (Petroleum)
21 Jun 12 17:00
No offense meant.
dcasto (Chemical)
22 Jun 12 9:26
the question was calculating zfactor to find LINE PACK. He found NX-19 and was having problems. Here is a simple way to get the same answer. Now, if the OP was trying to replicate API measurement, yeah the choice of z factor subroutines is limited.
BigInch (Petroleum)
23 Jun 12 11:10
No, "linepacker" was the user name of the guy that asked the original question about NX-19 a long time ago. This post is a correction to the code that was posted in the referenced thread.
Close Box
Join Eng-Tips® Today!
Join Us             Close
