how to apply the DOF in Ansys Workbench?
Hello, my problem is how to apply the degrees of freedom on both ends of an aircraft fuselage in Ansys Workbench. I want to keep the same hoop stress over the entire surface of the fuselage (especially in the middle of the fuselage). I only apply the internal pressure in the fuselage as a first step, after, I will apply the bending moment. thank you for your support
