belt filter press for dewatering
hii
i need to design a BFP for my project, i really need help cause i don't know where to start at.
first of all assume that 1000kg/day of sludge is enterring the BFP after having passed through the gravity thickener.
now we need to find the amount of BOD, COD and TSS lost, and these amount in the dewatered sludge as well to know its flowrate. cake is also formed and i need to know its flowrate and what to do with it afterwards.
polymer is added in the BFP, how much is needed for the 1000kg/day of sludge. what polymer can used?
since i have to design it, i need to know its structure, like its size, the belt size and so on. if possible can i get pictures with dimension so that i can draw it in autoCAD (front view, top view, cross section view, side view and so on)
thanks for your comprehension,
d.r
d.r
RE: belt filter press for dewatering
You can get the information that you need from the Metcal & Eddy textbook or Komline Sanderson (BPF Manufacturer).
Isn't there someone around who can help you? This is a pretty big piece of equipment to learn on.
