12V DC Motor that produces a flow of 600mL/min?
Hi Everyone,
I am looking for a motor that works under 12Volts and that can produce a flow of at least 600mL/min
I am not sure what RPM's is required to generate the flow of 600mL/min. The liquid being use is water.
Thank you for the help in advance.
RE: 12V DC Motor that produces a flow of 600mL/min?
Step 1 - Size pump.
Step 2 - Select motor.
Good luck,
Latexman
There is also a Pump Engineering forum that might be more appropriate for your question.
Good on ya,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
"12 VDC pump" yields a zillion hits, here is one page with dozens of pumps that match the spec you gave:
http://www.nextag.com/12v-dc-water-pump/products-h...
Good on ya,
Goober Dave
http://www.geotechnical.net/Merchant2/merchant.mv?...
