Hand calculations
Hand calculations
thread727-296596: Hand Calculations
Hello everyone
Im a mechanical engineer and I have two-years FEA experience. I was talking the other day with a friend of mine about hand calculations in order to make sure that the FEA results agree with what the classical theory says.
But normally for my analysis I just need to do equilibrium checks and only once I calculated a beamed structure which I could model as a free body diagram so I could check the results.
I would like to know, for static analysis, which hand calculations do you perform on a daily basis in your calculations?
BR
Hello everyone
BR
RE: Hand calculations
Tobalcane
"If you avoid failure, you also avoid success."
“Luck is where preparation meets opportunity”
