Cost of installing a 8'' steel sewer pipe
what is the cost of install a 86' long, 8" steel pipe? The cost should include trench diging fee(3 feet deep), labor fee, equipment rental fee, cost of purchasing pipe.
Jason Li
RE: Cost of installing a 8'' steel sewer pipe
The cost for installing sewer pipe are highly dependent on the location. Not sure if anybody is using steel for sewer pipe. PVC or ductile iron are probably more common. 8-Inch sewer pipe installed typically runs $75 to 100 per foot.
Here's an online estimate that shows you how to do an estimate:
http://www4.ncsu.edu/~rcborden/CE481/Project_Manag...
Bimr is right about cost being a function of location. Check your state DOT website. You should be able to find unit prices from their projects.
You may want to include the cost of the barrier to keep it from being a tripping hazard <G>. As a WAG, about $120 per foot... not much of a run...
Dik
Thank you all
