Fireproofing 2x12 wood joists
I have a situation where three A/C units were placed on top of a flat roof that has 2x12 wood joists. There is a hung ceiling and any fire could potentially cause the units to fall thru roof. The roof covering is rolled asphalt and the units that weigh about 500 lbs are placed on a couple of pressure treated 4x4's directly on the roof.
This is not how we do it now but 40 years ago, it was probably OK. Now the Town wants n engineer to OK it. The roof framing is OK for the snow loads and the units but have to make sure I get a 1 hour fire protection. Is there anything out there that would do that w/o imposing additinal or at least significant additional loads on the roof structure.
Thanks in advance.
Thanks in advance.
RE: Fireproofing 2x12 wood joists
Dik
